power to high after new cal ride
pajobv
Post by pajobv »
iBike Ride_24_10_2016_1119_52_km.ibr
(609.5 KiB) Downloaded 498 times
iBike Ride_17_10_2016_1450_4_km_CalRide.ibr
(46.49 KiB) Downloaded 514 times
Hello, on 17-10 i did a new cal ride because i changed the hight from my handlebar. Today i did a ride and the power seems a bit to high so i did check calibration and after that the power seems way to low. There was a difference in the wind scaling and fric. Which one should i use?
Re: power to high after new cal ride
Your 57 km ride file looks OK. In the ride file there are portions where there are substantial headwinds. If you do a check calibration this will lower the power numbers.
You should only do Check Calibration when there is an out and back ride. The elevation profile shows that this was not an out/back ride.
pajobv
Post by pajobv »
Thanks John for the very fast response!
PCM67
Post by PCM67 »
I normally tag in a cal ride at the end of a ride. You can push centre button to reset your ride to be new, goto settings then select Cal ride then do a warm down out and back in ride worthwhile and means you dont have to suit up just for a 1.6km ride.
pajobv
Post by pajobv »
Schermafbeelding 2016-11-12 om 15.14.03.png (75.64 KiB) Viewed 8219 times
today i did an out and back ride, because i still had doubts about the wattage, there was a big difference after check calibration. Windscaling and fric where way off, which one should i use. I think the original had to high wattage and after is to low.
out and back_12_11_2016_1201_53_km.ibr
(629.87 KiB) Downloaded 556 times
This ride shows your wind scaling was too high, causing high watts.
In the Check Calibration feature, click the Send to iBike button to update your profile. That should fix things.
