Est CDA Riding Position
Q&A for all things iSport
Panelman
Post by Panelman »
Hello,
new iSport owner and I have a question on entering the riding position value. When I have selected "hoods" and pressed the center button and then exit Setup, should I be able to see "hoods" as the riding position when I reenter Est CDA? When I reenter Est CDA to double check my entries all riding position values display as "No"
Thank you
coachboyd
Re: Est CDA Riding Position
Post by coachboyd »
When you enter the est cda screen, it should be to change your height, weight, or riding position. If you circle through and select 'no' for every option it will keep your last selection (in this case the hoods). It will give you the option to choose drops of aero bars when going into that screen.
Once you've found the position you plan to ride in, use the up arrow to select "Yes", the press the center button. The CdA for the selected ride position will be loaded into your iBike and you will return to the main screen.
