I have an iBike stem mounted computer. I have the Garmin mounted (on the new mount) in front of the stem. The Garmin is just about below the air port. The little garmin joystick is about a mm lower that the very bottom of the iBike air port. Will this configuration cause readings in the iBike to be off?
For the record, this a BDop Dashboard Genie Pro. Trying it out on the winter trainer. It's similar in style to the FSA mount, but being made of metal it's rigid and doesn't wobble around. It's also lighter.
