AeroPod CDA (oleksiy)
TdeCampo
Post by TdeCampo »
I use profile 3 most of the time and as John said, the old Aeropod CDA is the choice if time advantage is important.
The problem I have is the following:
Suppose I ride a downhill and I am in drops, so the CdA will go down accordingly, then a climb follows, the speed goes down and the CdA will stay the same (fix) until speed returns. The problem is that the time advantage continue changing so it will be worthless when the flat terrain and speed comes out. The time advantage should not change IF the CdA does not change because low speed.
I wonder if I am doing something wrong?
Re: AeroPod CDA (oleksiy)
You aren't doing anything wrong.
What's happening is that your CdA goes down on the downhill while in the drops, as you report. However, at the bottom of the downhill, you start going up, slowing down greatly.
CdA is a difficult quantity to measure below a certain bike speed. When you're traveling slower than the threshold speed our firmware locks-in the last-measured CdA, until speed is subsequently increased above threshold speed.
So, the *low" CdA continues on the uphill, and TA is wrong...
I will see if we can find a workaround for this edge case.
TdeCampo
Post by TdeCampo »
John, thank you very much!.
BTW the correlation of the aeropod and the DFPM is a carbon copy; I used to use the DFPM to re-calibrate the AP/PP now I do not do it any more, both are the same. Great work.
TdeCampo wrote: Wed Aug 14, 2024 5:18 pm John, thank you very much!.
Thank you!
kdx200
Post by kdx200 »
Hi guys, just asking as i did not find this app in the garminIQ with my edge 1050.
Is it possible to get the app file to download and then copy to my 1050?
thank you in advance
kdx200 wrote: Sun Jul 06, 2025 10:34 am Hi guys, just asking as i did not find this app in the garminIQ with my edge 1050.
Use the AeroPod 2.0 app, available here:
https://apps.garmin.com/apps/41ca192f-2 ... 496e?tid=1
The original AeroPod app is no longer supported...
