Set up device in Isaac Powerpod 4
JohnD
Post by JohnD »
Hello,
I am setting up my new Powerpod 4 in Isaac using Device set up.
I use a name for a new profile (in my case Cervelo) and providing all needed information. After closing I am doing the calibration ride, including connecting sensors. This all works well.
Only the name Cervelo is not saved. If I start Isaac again the first profiel is named: Unsaved (Initial Set up). How can i name this correctly.
Trying to set up a second bike gave the same issue?
Many thanks, John
Re: Set up device in Isaac Powerpod 4
Go to Edit/Edit Profiles...
Click on the profile name you want to name. In the "Basic" tab, click on Profile Name and rename your profile to whatever you like.
This should fix things.
JohnD
Post by JohnD »
Resolved. Thanks!
