Calibration on 2 bikes
kurt
Post by kurt »
Hello,
I have 2 bikes. On that I use for home-work transportation and a bike for recreational use.
I have a powerpod v3 and I know that I can have 4 calibration files.
However my questions is:
If I change the powerpod from 1 bike to the other, do I each time have to re-calibrate? (Is the tilt not changed?)
Many thanks for your help
Kurt
Re: Calibration on 2 bikes
kurt wrote: Fri Jan 14, 2022 2:30 pm Hello,
Kurt
1) Use a different ANT+ speed sensor for each of your two bikes
2) Pair, setup and Calibrate "bike 1" with profile 1
3) Use Isaac or our app to switch to profile 2 (bike 2).
4) Make sure your speed sensor for bike 2 is activated and that your speed sensor for bike 1 is off (or bike 2 is 100 feet away from bike 1).
5) Pair, setup, and calibrate bike 2 using profile 2
You will do the pairing, setup and calibration ONE TIME for each bike
When you're ready to ride, pedal your bike for 5 seconds, then wake up PP. PP will automatically figure out which bike you're riding and automatically switch to the correct profile for that bike.
kurt
Post by kurt »
Thanks;
and the tilt? because each time that I change the powerpod from bike, the tilt will be changed; Doesn't that change the power output?
BR
Kurt
kurt wrote: Sat Jan 15, 2022 2:28 am Thanks;
BR
Kurt
Tilt errors will auto-correct during the first 90 seconds of the ride.
kurt
Post by kurt »
Thank you for your answers.
