PP V3 - How Far Is 'Slightly'
stevepmoore
Post by stevepmoore »
As per the title, how far is 'slightly' pointing down?
From having to mount my previous V1 PP level, I'm unsure as to what 'slightly' means. I have just measured and my V3 is pointing down by 7 degrees. Is this too much? I assume that at a certain point the PP will assume you are constantly riding down hill and under-read as a result?
Please could someone give me some advice as to what angle range is acceptable.
Thanks in advance
Steve
kdx200
Re: PP V3 - How Far Is 'Slightly'
Post by kdx200 »
The pp cant move/tilt too much when attached, i did not measured the angles though...so i locked always pointing down (at maximum) and every time im ataching it is always in the same way.
stevepmoore
Thank you for the reply.It’s the initial set-up angle that I need some advice on. Once I have that i should be ok.
Used yesterday for the first time and seemed to be reading lower than expected when compared to similar efforts with my old PP.
stevepmoore wrote: Fri Nov 08, 2019 8:26 am Thank you for the reply.It’s the initial set-up angle that I need some advice on. Once I have that i should be ok.
PP automatically calibrates itself for the mounting angle. You don't have to have an "exact" angle; you just want it pointing approximately level.
If you want to post ride files from your old unit and your new PP I will see if there is a reason for any differences.
