PowerPod Failed Me Today
Kcblair
Post by Kcblair »
For some reason, my PP won't pair to my Garmin head unit. Speed sensor is paring with head unit, but PP refuses to pair. Nothing has changed, lately. I did a hard reset, but nothing. One press of the button , light flashes green, for some time, then goes out. Press 5 times to turn of and tried again, won't pair with head unit. The profile is saved in Issac, so what can I do , (short of recal ride) ?
Thank you John.
Re: PowerPod Failed Me Today
Hmm...try a hard reset: press-hold button for about 12 seconds. Light will go out momentarily, then turn back on. Release button.
Hopefully this will fix things.
Kcblair
Post by Kcblair »
Solved, some how, issac shows 2 profiles , sharing the same speed sensor ID. Software thinking for itself. Reassigned the correct sensor ID to the correct profile, all is working. Gota love it .
Kcblair wrote: Fri Aug 09, 2019 2:31 pm Solved, some how, issac shows 2 profiles , sharing the same speed sensor ID. Software thinking for itself. Reassigned the correct sensor ID to the correct profile, all is working. Gota love it .
:D
Kcblair
Post by Kcblair »
Thanks for your quick response john. Sometimes, after a short knap, (26mi. 1700ft. climbing) the ole brain functions.
