Syncing HR
Denodan
Syncing HR
Post by Denodan »
Can you also sync a HR strap to the power pod also?
Re: Syncing HR
Yes.
Denodan
Re: Syncing HR
Post by Denodan »
Is there accually any indication the HR strap has synced? Or can you only tell through issac?
Re: Syncing HR
Only through Isaac. You'll see HR data in the ride file (which is the point of the sync!).
Denodan
Re: Syncing HR
Post by Denodan »
Thanks, and would presume hr and cadence would lead to more accuracy of your data and accuracy of your powerpod power accuracy.
Re: Syncing HR
HR will have no effect on accuracy. Cadence can, sometimes, be helpful if you're coasting on a downhill.
