Hi john,
I installed a power pod on my bike yesterday, and after a knife riding, attach a riding file.
Please make sure that your kneeling is working properly.
Weight: 60kg
Height: 167cm
Base mount
Riding check
Riding check
- pp_04_25_2019_0759_10_km_HiDef.ibr
- (196.17 KiB) Downloaded 120 times
Re: Riding check
I corrected your profile, attached.
Paste this profile to your desktop.
Then, connect your unit to Isaac.
Then, use the command "Edit/Edit Profiles/Import..." to select, then import the corrected profile into Isaac.
Finally, use the command "Edit/Edit Profiles/Send to Device" to transfer the connected profile to your unit.
- Hans.ibp
- (567 Bytes) Downloaded 137 times
