Newton+6 cannot connect to PC
Stephan71
Post by Stephan71 »
After not using my Newton +6 and its battery went dead I cannot connect it to my PC (Windows 10)
The Newton sat untouched in a desk drawer for a couple of weeks, and before the battery went dead everything was alright. So there could not have been any damage to the USB port.
Full recharge was no problem, and the device works perfectly on the bike.
The only thing that does not work is that my PC does not recognize the Newton, so I cannot download anything from the Newton or change any settings on the Newton via Isaac.
I already sent a equest to Velocomp, they advised to re-install the appropriate drivers and sent my me the related links.
I made absolutely sure all anti-virus software, firewall etc. were disabled before I downloaded and installed everything, also updating to the latest version of Isaac in the process.
Nothing changed, Windows does not recognize the Newton, neither does Isaac.
So what can be done to connect my PC/Isaac with my Newton?
Thanks for the help.
Re: Newton+6 cannot connect to PC
Did your Newton work previously with your Windows machine? If so, your USB cable may have gone bad.
Stephan71
Post by Stephan71 »
Thanks for the reply.
And yes, it did work previously. I tried to connect with three different cables. Connecting my Android phone to the PC works with all of these cables, as does charging the Newton. The only thing that does not work is the PC recognizing the Newton. So what can it be?
If your Newton worked before with your computer, and your cables are good, then something has changed on your computer--perhaps you installed a new device, such as Garmin?
You can try installing the latest version of Isaac (version 5.01), which is available from our website https://velocomp.com/isaac-software-installation/. Other than that, I don't have any additional advice.
Stephan71
Post by Stephan71 »
Sorry for my late answer.
Meanwhile I replaced the whole unit. The new one works flawlessly.
Yet, I have another problem. I cannot find the function how to reset my total ride time.
You can easily reset the odometer (btw. in the German language version of Isaac it says "Höhe" which means elevation, should say: "Gesamtdistanz"/"total distance") but not time. Where did you hide the total distance reset?
Thanks a lot for your support.
Stephan71 wrote: Thu Jul 16, 2020 10:43 am Sorry for my late answer.
Which product do you have now? What is its firmware version?
