Have replaced my computer so need to install and setup isaac. Previous system was Windows 7, new one Windows 10.
How do I get access to my previous setup files, eg, profile, licensing, etc. I assume I need to move or copy some old files.
Installing Isaac on a new computer
Re: Installing Isaac on a new computer
I am not at all familiar with Windows. On Macs there is a "migration assistant" that allows you to transfer the contents of your old computer to your new computer. I am sure there is something comparable in Windows. This is what will get your Isaac program and files over to your new computer.
longinthetooth
Thank you.
I have all the files. But I don't know what the files that I need to move/copy are called.
I have had to reinstall Isaac and it therefore sets up the profiles, settings, etc as if if this is completely new user. My data files of previous rides, isn't an issue, they can be read by the new installation.
If you open a recent ride file on your new installation of Isaac, you can extract its profile with the command Edit/Edit Profiles/Get from Ride File
