Best way to handle commuting with a rucksack
Darkstar
Post by Darkstar »
This is similar to another thread from last year, but different enough to be worth asking.
I ride what is basically the same route from home to work & back, but sometimes it's for exercise/training & sometimes it's the way to get from A to B. On the latter I often have a significant sized rucksack (10-15 litres & up to about 5kg in weight)
Distance is about 34km & there's about 500m of climbing in the downhill version of the route.
I'm curious about the effect of a 6-7% increase in bike weight might be (plus the effect on the CdA of having a parachute for the faster sections), but that currently stops short of doing a full profile calibration with the rucksack load on board!
Can I just duplicate the profile & add a bunch of Kg to the rider weight? Or should I add it to the bike weight?
Should I tweak the CdA at the same time? (is it different if I add weight to a different component of the total weight?)
I've not got an aeropod/way to easily measure CdA so if someone wants to throw a best guesss in here that would be good :)
Re: Best way to handle commuting with a rucksack
1) Yes, you can duplicate the profile and add weight in the Edit Profiles command.
2) It's likely that your rucksack adds drag. My "GUESS" is about 10%. You can update this in Edit Profiles, too.
3) You're correct that AeroPod would be able to quantify the change :-)
4) If you have multiple profiles for the same bike, you'll need to switch manually between them.
