AeroPod ANT+ Compatible Computers (Garmin Edge 810?)
Carcinogent
Post by Carcinogent »
Just to confirm is *any* ANT+ computer compatible with the AeroPod or only Gamirn IQ and Lezyne ones as per the product description?
Is there a list of what is compatible in general and in particular is the Garmin Edge 810 compatible?
P.S. I have been going through the various lenghty and detailed discussions on Timetrialing forum/slowtwitch etc. and I have to say I am impressed! If i don't have to invest couple hundred to change/upgrade every gadget I own (I already will need a speed sensor, though those are cheap, albeit ugly) I will be definitely be eager to be an early adopter.
Re: AeroPod ANT+ Compatible Computers (Garmin Edge 810?)
AeroPod CdA data (CdA, Wind speed, hill slope, and Time Advantage) can be displayed on a Garmin Connect-IQ Device (that is, a Garmin device that works with Connect-IQ apps).
Here is a link that shows all Connect-IQ devices:
https://developer.garmin.com/connect-iq ... e-devices/
The Garmin 810 is not a Connect-IQ device.
Another (very cool) way to display AeroPod CdA data is the Everysight Raptor glasses:
https://everysight.com
Note that any ANT+ computer, from any manufacturer, will display AeroPod power data.
Carcinogent
Thanks for the quick reply. I am a bit confused so to clarify...
If I understand correctly:
To *display* on your ANT+ computer (while you ride), CdA related data you will need an IQ device.
However to *record and analyze* Cda post ride what is required?
I guess I am not fully grasping what is paired with what and what is sending data where...
So if one has a Quarq PM, ANT+ Bike computer and an Aeropod what is the sequence of making the setup work and record data?
1) AeroPod CdA data is recorded in AeroPod ride file
2) AeroPod CdA data is displayed live in Connect-IQ Garmin devices
3) AeroPod CdA data is analyzed, post-ride, in Isaac software, included with AeroPod
Carcinogent
Excellent thanks for the clarification!
TuRu00
Post by TuRu00 »
Hello! Does Isaac write cda and time advantage data to auto export-CSV files? I am very interested in post analysis on Golden Cheetah.
TuRu00 wrote: Wed Aug 22, 2018 8:17 am Hello! Does Isaac write cda and time advantage data to auto export-CSV files? I am very interested in post analysis on Golden Cheetah.
sorry, but no.
