Was in a head wind a couple of times today so went into the drops for a while. Calibration was done on the hoods. Should I tweak anything?
Vince
Accuracy when in the drops?
Re: Accuracy when in the drops?
No need to change anything. When in the drops your reported watts will be 0% to 5% too high--it depends on your actual ride position.
Since you are in the drops only for a short time, the effect on overall results will be immaterial.
