GPS from Wahoo Bolt
Titan
GPS from Wahoo Bolt
Post by Titan »
Hi John! Can I import GPS data from my Wahoo Bolt into Isaac ?
Titan
Re: GPS from Wahoo Bolt
I'm not familiar with the ride file format of Wahoo. If you can export the file in .gpx form, this should be able to be read by Isaac.
Titan
Post by Titan »
Velocomp wrote:I'm not familiar with the ride file format of Wahoo. If you can export the file in .gpx form, this should be able to be read by Isaac.
The Wahoo file format is a .fit . I’ll try to convert to .gpx, let you know it.
Regards
Titan
