ONLY adding a sensor to the PP
kdx200
Post by kdx200 »
i ve a new HRM and id like to add it for the post procesing data in the isaac.
Whats the procedure? 4sec in the pp button? does the pp recognize and add this new sensor only or i must to "re-pair" the other ones (the toher hrm, the cadence sensor and so on?
thank you
Re: ONLY adding a sensor to the PP
You will need to re-pair all your sensors at the same time.
Make sure everything is awake, then press-hold for 4 seconds until the light flashes. Then release the button and wait until light goes out.
