PP fails to download ride data into Isaac
rincewind4
Post by rincewind4 »
I am unable to download ride data from the PP.
PP appears to connect in Isaac screen (USB icon green). Tried getting FW & S/N from unit and changing profile and it appears to work (doesn't present an error).
But when I try to download file data the following occurs:
- window "Getting file list - please wait" appears
- progress bar gets to about 3/4 then the window disappears.
- then the usb/pp to pc icons both grey out and come back up (connection to the device appears to reset)
I have tried many different cables and different PCs with exactly the same problem.
WIN 7 & WIN 10
Re: PP fails to download ride data into Isaac
rincewind4
Thanks for your help so far, but I am still having problems.
I erased all ride data on the PowerPod as advised. (not ideal as I have now lost about 2 months of ride data). Since doing this though the unit has failed to record any ride data or show power on my Garmin.
The light flashes red/green constantly - and early on a ride it sometimes briefly displays a power figure, but goes blank again.
Additionally it fails to connect with several usb cables - pretty much only one from another device seems reliable. I suspect if a ride file was corrupt then there may well be an underlying problem which caused that - and I am reluctant to persist with attempting to something to work only to find it fails or is unreliable further down the track.
rincewind4
Yep - that is who advised there may be a corrupt ride file and to erase the ride data.
Please email Tom again. It sounds like there might be a different problem.
Jay A
Post by Jay A »
I am experiencing this exact problem. Is there a solution?
Jay A wrote: Mon Jun 24, 2019 7:33 pm I am experiencing this exact problem. Is there a solution?
