So, where is that folder?
Where is that default folder to which iBike saves ride data? I've defined my own default folder, but when I first used older versions of iBike, I'd occasionally forget to change the folder; iBike would save the data to its default; and the data would disappear into, maybe, another dimension.
Be an organ donor. When you're dead, you won't need 'em.
Re: So, where is that folder?
Search your computer for files that begin with "iBike"; unless you've changed the default name you'll be able to find where your ride files are hiding.
I've got a folder I made for my rides, but I never found the folder that iBike had as default. I used Spotlight, and it found nothing. It's not really a problem anymore, just more of a curiosity. FWIW, there were no issues with installs.Velocomp wrote:Search your computer for files that begin with "iBike"; unless you've changed the default name you'll be able to find where your ride files are hiding.
On my Windows XP system the folder "ibike rides" is located under "My Documents". Since I specified a different default folder nothing ever goes there hence it is empty.
