Isaac 4.1.1 has been posted
Changes for 4.1.1:
Mac
Fixed a bug (exists on Mac build only) that could cause incorrect CdA values for ride positions other than "hoods".
Windows 7 and higher:
Fixed video script errors caused by a recent release of Internet Explorer. These errors were particularly noticeable on the "Device/Device Setup..." menu
NOTE: Isaac updates are incompatible with Windows XP and older. You'll get a (non-fatal) error message if you try to install Isaac 4.1.1 on Windows XP or older
Mac and Windows:
Updated Help documents
Updated various images
Removed non-functional buttons for Training Peaks uploads. You can still get your ride file data on to Training Peaks. 1) Use the "File/Export for Training Peaks..." command. 2) Launch TP, then click the "Import" button, to import your file
Updated Velocomp URL in several places
GKuch
Re: Isaac 4.1.1 has been posted
Post by GKuch »
Isaac 4.1.0 appears to load, but hangs when opening on my Macbook Pro retina running Yosemite (10.10.5). I downloaded 4.1.1 and it does the same thing. Command Q will not make it quit. I have to force quit to get it to quit. Also, when I hover the cursor over the Isaac icon on my toolbar, it says Isaac for Mac, but if I control click on the icon, it shows as Isaac for Windows. Is this normal, or have I somehow downloaded the Windows version?
Please download and reinstall, making sure that when you launch Isaac for the first time, that you use the "control-click-open" to install. (see instructions)
GKuch
Post by GKuch »
I should have mentioned that I was using that process to open Isaac. But, just to be thorough, I downloaded, and went through the whole process again per your instructions. Unfortunately, I got the same result. It hangs on starting. It loads, and then says it is starting, but it just hangs. I gave it over 20 minutes. No go.
