Is the Garmin Edge/Virb mount compatible with PowerPod?
Nibbler
Post by Nibbler »
Does anyone know if the Garmin VIRB mount is the same as the Go-Pro used for the Powerpod?
If yes, it means I can use this:
http://www.wiggle.co.uk/garmin-cycling- ... edge-virb/
Re: Is the Garmin Edge/Virb mount compatible with PowerPod?
I think the Tate Labs mount is made from flexible plastic. If so it won't work with PP.
The Garmin mount is fine (we've seen one) but it looks like it isn't available.
