How to perform and O&B ride?
beermat
Post by beermat »
Hi all,
I understand that in order to perform a check calibration a short O&B is required.
However, if I want to do an O&B and then after go off on a longer ride, is it necessary to first download the O&B to Isaac or will the software on the PP automatically generate two ride files?
TIA.
speedyvelo
Re: How to perform and O&B ride?
Post by speedyvelo »
1. To generate two files you have to stop riding for 20 minutes so the PP turn off automatically and it will generate 2 files after you wake up the sensor press the PP bottom and continue to ride.
2. You can download the whole thing then select the O&Back part of the ride / keep only the select part and then save it as a new file. That should do it, I've done this approach and it seems to work but.. I am not sure and I posted a thread few day ago about "advance"set up but I have not gotten any replies yet.
Whenever you do an O&B calibration, at the end of the O&B your PowerPod/Newton automatically calculates the calibration factors. You don't have to connect to Isaac.
Also, after an O&B a new ride file is also started automatically. So, if you continue riding after an O&B, your "official" ride file will be separate from your O&B ride file.
