Unable to pair with Cateye Stealth Evo +
thomask
Post by thomask »
I can't seem to pair the unit with Cateye Stealth Evo + Here is what I did...
1. I clicked on the PP. The LED turned red.
2. I then chose the PW1 option on the Cateye and hit the sync option.
The Cateye keeps searching but cannot find the pod. Am I doing anything wrong? Please see attachments...I was able to pair the Cateye Speed and Cadence sensor and my Mio Link HRM without any issues to both Cateye and PP.
Thank you!
Ken
Re: Unable to pair with Cateye Stealth Evo +
You need to follow the instruction sequence...
BEFORE attempting to pair PP to your Cateye, you must FIRST pair PP to your ANT+ speed sensor. When pairing is successful, your status light will change from RED to GREEN (successful pairing). Then, the light will go out. If you click the button again the light will be solid yellow.
PP will not send power signals until after it is successfully paired to a speed sensor.
