This may be a repeat as I already sent an email to support about my questions...
1. How does the Heart Rate sensor pairing work with the Power Pod? I have an ANT+ wrist based optical heart rate sensor made by MioLink. Works perfectly with the Cateye Evo Plus. Do I need to pair the MioLink with the PowerPod as well? If paired with the PowerPod, does the PowerPod transmit data to the Cateye so I can view all of the Speed, Cadence, Power and Heart Rate on my Cateye?
2. When downloading data, do I get it from PowerPod or the Cateye?
Thank you for your time!
Ken
PowerPod with Cateye Stealth Evo Plus
Re: PowerPod with Cateye Stealth Evo Plus
If your HRM is able to transmit data over ANT+ then You need to pair it to PP directly. You need to pair all the cadence sensor , speed sensor, HRM directly to PP as well as the cateye. And then pair the PP to cateye to see the power data in realtime in cateyethomask wrote:Hi,
Ken
The powerpod transmits only power data to cateye. You can view all speed cadence , power and HR in your cateye as the data transmitted from the respective sensors directly go to both PP and cateye. Since the other sensors are paired to PP too you can see data from them as well in Isaac
