Powerpod mount for roadbike aero handlebar
Martinbj
Post by Martinbj »
Is there any mount out there that could work with an road aerobar like these?
https://cyclepathpdx.com/wp-uploads/201 ... Detail.jpg
A verry flat bar.
nicholp1
Re: Powerpod mount for roadbike aero handlebar
Post by nicholp1 »
I found this top view picture
You might be lucky and be able to get the standard PowerPod mount on the round section of the bars next to the stem before the bars change profile.
Martinbj
Post by Martinbj »
Unfortunatly it doesn´t look like that so is there maybe some kind of gopro mount that would work?
Guido_K
Post by Guido_K »
I am using this one for my Zipp Vuka Aero handlebars. It mounts directly onto the stem and does not flex.
http://www.fouriers-bike.com/en/pro.php ... cid=28&f=5
nicholp1
Post by nicholp1 »
Are there any bolts under the stem for mounting a out front computer mount?
beardyweirdy
Post by beardyweirdy »
I have one these fitted to to one my bikes, it fits using the top pair of stem bolts (comes with extended stem bolts supplied) and has Garmin mount on to and GoPro underneath. The Powerpod fits okay on to mine.
You can pick them up quite cheaply if you ship around too, and they're a nicely made piece of kit.
Meanwhile, I've now got a Canyon Aeroad on order with an integrated aero pair of bars (the HF11). No idea how I'm going to fit my Powerpod to it (although I do have one of Canyon's custom Garmin mounts for it. Raceware Direct do a 3D printed mount for them, but it's ugly as sin, undoes all the aero work, and is plastic. Rec Mounts in Japan do one, but I can't find aUK supplier of that particular item and it'd be expensive to import from Japan.
http://www.rec-mounts.com/products/cany ... 31-garmin/
