power too low after new cal ride
pajobv
Post by pajobv »
After lowering my steer for about 1 cm i did a new cal ride. My power after that seems to low, i think possible 30 watts for my NP, according to my heart rate. I think the aero factor is a little bit low, i was riding on the hoods in the cal ride.
iBike Ride_23_04_2016_0920_5_km_CalRide.ibr
(56.28 KiB) Downloaded 414 times
pajobv
Re: power to low after new cal ride
Post by pajobv »
Here is the file from the ride after the cal ride.
iBike Ride_23_04_2016_0930_51_km.ibr
(521.3 KiB) Downloaded 429 times
Before your new cal ride your wind factor was 0.691
The wind factor measured in your new cal ride was 0.687--an immaterial difference!
So, the new cal ride had no effect on your Newton's settings.
Remember that NP is heavily dependent on the amount of surging and coasting you do. In this ride you were pedaling almost all of the time, at a pretty constant speed, so that NP is close to average watts.
Please send a ride file done from before your new calibration--perhaps that will reveal something.
pajobv
Re: power too low after new cal ride
Post by pajobv »
Ok John thanks, here is a file before.
iBike Ride_13_04_2016_1712_47_km.ibr
(483.55 KiB) Downloaded 417 times
pajobv
Post by pajobv »
I ordered a iBike solo front mount, should i do a new cal ride again when i received this? The newton is now on my stem.
pajobv wrote:Ok John thanks, here is a file before.
The two files are within 20W of each other, plus you did some sprint interval work at the end of your earlier file.
You are OK
pajobv wrote:I ordered a iBike solo front mount, should i do a new cal ride again when i received this? The newton is now on my stem.
Yes, you will need to do a new cal ride. Your wind factor will be significantly different.
pajobv
Post by pajobv »
Thanks John for the quick response!
