Check Calibrate Function: Profile or Device?
kenf
Post by kenf »
Does the Analyze>Check Calibration function do a recalibration of the particular profile used during that ride or of the device? e.g., if I have different profiles for different wheel sets (same bike) would a "check calibration" for each profile or just one "check calibration" in any profile be the fine tuning I need?
Isaac User Manual says "WITH THIS CHANGE, IT SHOULD NOT BE NECESSARY TO PERFORM FURTHER “CHECK CALIBRATIONS” FOR THIS UNIT" indicating it is a device (all profiles) adjustment.
Re: Check Calibrate Function: Profile or Device?
Check Calibration checks the particular ride file and, if desired, adjusts the profile for that ride. It works on the active profile only.
