iBike ride shows the wrong start time (1 hour earlier)
rstrom
Post by rstrom »
I just posted my ride to Strava and saw that it said I started at 6:30am today when I really started at 7:30am. The ride file in the Isaac software says that the ride started @ 12/14/2013 6:44 AM and the data in the CSV file says 2013-12-14T13:30:36Z (the offset is -7 / MST / Arizona time zone - no DST).
I looked at the last few rides that I've posted to Strava and the start times on those seem OK. The most recent ones being Tuesday and Thursday this week.
I've been poking around and cannot find where you set the time zones (eve though it is correct I'm curious).
Any idea what's going on here?
Re: iBike ride shows the wrong start time (1 hour earlier)
Click the Enviro button of your Newton, to see what time your Newton is set. That time should be the correct local time; in any event, it should be the time that is stored in your computer. If either time is wrong that is the source of your problem.
rstrom
Post by rstrom »
The time on my computer is correct (Internet time synchronization) and it is correct on the iBike.
I'm about to head out on a ride now ... we'll see what happens.
Robert
Rob =
Any chance you made (or did not) a time update after Daylight Savings? One hour seems too coincidental.
rstrom
Post by rstrom »
The one sane thing about Arizona is that we do not have any DST.
Same time all year long.
So ... no ... there is no chance that I forgot to change the time :-)
Robert
Rob -
Yep - I did see and know that you are in AZ - but did someone play with your computer and change the location - making the net logging think you were in a different TZ - which then was transferred to your Newton....
Either that or we can blame it on the snowbirds.
Cheers
rstrom
Post by rstrom »
The ride file said it was the right time zone and the time on the iBike showed the correct time.
The computer is set to the right time zone and has the correct time (it's my computer and no one else uses it).
I have no idea what it was and it has not happened since. Must be those snow birds :-)
