Hi all,
As a new ibike owner I currently trawling all the posts to understand how to get the most out of the snapshot/continuous cDa measurements.
I originally bought the ibike it was to gain the wind data to use in Golden Cheetah's aero lab, as I do a lot of aero testing but as the continuous cDa functionality gives real time info I'm looking to try this out.
I'm currently putting a list together of step my step items to get the most out of it/repeatability, such as doing the cal ride, doing a tilt and wind calculation etc in between changes in setup (bar angle, height, pad width etc).
Is there a good guide for this already or any good topics I may not have seen that would be useful?
If there isn't I think I will start collating all info in this forum topic.
Cheers
w01fy
Getting the most out of an iBike for snapshot/continious cDa
Re: Getting the most out of an iBike for snapshot/continious cDa
w01fy,
I have had an Aero iBike for years, the Newton+ now but no DPFM![Sad :-(](./images/smilies/icon_e_sad.gif)
However, there are lot's of posts buried in this forum about that but my quick search did not pull up a gold mine.
I did continuous cDa and DPFM cDa in the search box upper right, you may want to do that and expand from there.
Also googled continuous cDa and that also got a few hits in this forum as well as an interesting post here:
http://coachrobmuller.blogspot.com/2009 ... nt-to.html
I did not try snapshot cDa (all I can do with just the Newton+) but you may want to do that search too.
Hopefully some with the DPFM will start adding to your thread, it is a great idea!
Regards,
Regards,
Thanks for the advice and link Russ.
I've emailed the chap in the blog for any best practice tips.
I think I will email velocomp as well, as they must have some pointers from there own testing/development
I'm collecting lots of info now, so will post up a thread at some point.
A question for someone though.
I've read that doing a cal wind and tilt call inbtween aero testing is a bad idea, I think the analogy used was, its like changing the tone on your stereo mid concert.
Now being that some of the position changes I will make include changing the handlebar position/stem angle, this may indeed change the tilt.
I presume it is acceptable to do a tilt cal in this situation? or would it be better to simply ensure the angle doesn't change (as best as possible).
I can't obviously do a cal ride in-between as I'm looking to use the continuous cda measurement to show improvements round a set course.
