My newton doesn't seem to want to enter "fit train" mode after the upgrade to firmware v 4.00. Pressing and holding the right button just navigates to the time/temp screen.
Also a minor thing is that Isaac still asks you to perform a tilt/calibration on the unit next time if it detects a tilt change is required.
Entering "Fit Train" Mode
Re: Entering "Fit Train" Mode
Prior to installing new firmware or software, we strongly recommend you check the release notes to see what is changing.
Firmware release notes are available in Isaac "Help Documents/Newton FW release notes".
Software release notes are available in "Help/Isaac Release Notes"
Prior to updating check the version of FW/SW you are using. After updating ALL of the changes described in the release notes will apply to your unit.
The change you're asking about was actually implemented in release 3.02. Here's what the release notes say:
"Added a new “USER” menu setup that can be used to enable the Fitness Training Mode. The fitness training mode must be enabled in the USER menu now before the “Right Arrow Press-hold” function will trigger entry to the Fitness Training Menus."
So, you'll need to turn the Fit Train mode on in User sequence. Then it will work as it always has previously.
