Wind Cal
blp
Wind Cal
Post by blp »
I have done a Wind Cal inside before I ride. Before the Wind Cal, it shows readings of, say 2.4 or -1.6 for example. I press the centre button and the numbers settle at zero and the Wind Cal is "Done". After the ride, Isaac shows I had a tail wind the entire ride (would be nice wouldn't it?). I have to use the Analyze Wind in Isaac, set the Ave. Ground Wind to zero then the wind looks about right, a little head wind out and little tail wind back.
Am I doing something wrong when I set the Wind cal on the Newton?
Re: Wind Cal
Please post your ride file
blp
Re: Wind Cal
Post by blp »
Original file with appended file (data reset)
iBike_2012_12_30_0957_0_km.ibr
(395.16 KiB) Downloaded 453 times
Re: Wind Cal
It's important to do the Wind Cal correctly. Assuming you've done this, then your profile is incorrect.
I looked at your profile and the wind scaling factor was 0.57, pretty low. This would cause constant tail winds.
I did a Check Calibration step and got the modified profile, attached. Your WSF is now 0.97, quite reasonable.
Load this profile into your Newton and give it a try.
JRHblpprofile.ibp
(558 Bytes) Downloaded 381 times
blp
Re: Wind Cal
Post by blp »
Thanks John. I will upload that profile.
I do the Wind Cal indoors (no wind) or if outdoors, I cup my hand over the port.Is this correct? Reading more posts, I gather that I really shouldn't need to do a wind cal after a succesful cal ride. Correct?
Thanks again.
blp
Re: Wind Cal
Post by blp »
How do I upload the .ibp file. Isaac won't open it.
blp
Re: Wind Cal
Post by blp »
I figured it out.I'll give it a whirl today.
blp
Re: Wind Cal
Post by blp »
Hi John;
I've atttached a ride file with the profile you provided. No post-ride adjustments applied.
iBike_2013_01_01_1334_38_km.ibr
(505.3 KiB) Downloaded 419 times
Re: Wind Cal
blp wrote:Hi John;
If you perform an "Analyze/Check Calibration" on your ride file, you'll see that there is essentially zero correction. So, all is well!
blp
Re: Wind Cal
Post by blp »
Thanks for the help.
ScottChapman
Re: Wind Cal
Post by ScottChapman »
I have to say, being able to do the analyze.check calibration of a ride is a real benefit!
