An error has just appeared with new Newton/Isaac files. Downloaded the Newton file (as a .ibr). When I tried to analyze in Analyze Route a box with "Unexpected Ride Data File Type" appears. If I click OK on this (2 times) I can analyze my route.
What am I doing wrong???
Cheers - PRS
Re: Unexpected Ride Data File Type
There is a new version of Isaac out that is supposed to fix this issue. 1.0.2! Have you downloaded it?
I was using the 1.0.1 version so I have now updated!
Thanks mate, problem solved.
I wonder why Isaac didn't prompt me for a new download??
- lorduintah
What auto update setting do you have? Weekly or Monthly - if so, then you probably were not on schedule to see the update. (Look in your Preferences.)
I had it set to weekly and it wasn't a week since the last update! Set to daily now.
Thanks Tom.
All I have to do now is work out why I have turned into a low powered cycling Wus since I changed the Gen III for a Newton!
Thanks Tom.
