Temperature readings on Newton
The Newton measures temperature at the wind port.
The (new) digital wind sensor we are using is pre-calibrated by its manufacturer.
We've had a few reports that the temperature reading reported on the Newton screen appears to be a bit high.
We will investigate this and, if needed, provide a firmware update to fix the reported temperature.
In the mean time, don't worry; your Newton will work just fine!
Zoltan
Re: Temperature readings on Newton
Post by Zoltan »
Do you have any update about it?
Nope.
Post by Russ »
My only observation on this topic, having the RWS installed, is yes a few degrees higher readings. However, I guess with the RWS I may be stuck with that as John said the temperature sensor was in the air port, thus exposed to outside air (as I understood the post) so I suppose mine is not so well exposed.
If true, then I wonder if it would be beneficial to have a selection that says RWS present and then applies some positive offset, perhaps even a positive offset function of temperature. Just wondering.
Generally working quite well for me so far!
Russ wrote:My only observation on this topic, having the RWS installed, is yes a few degrees higher readings. However, I guess with the RWS I may be stuck with that as John said the temperature sensor was in the air port, thus exposed to outside air (as I understood the post) so I suppose mine is not so well exposed.
Good point; the RWS isolates the sensor from ambient air.
Zoltan
Post by Zoltan »
"The Newton measures temperature at the wind port"
I think that is the really good point. First I have just read your post rapidly, but when checked it again I suddenly understood that it should solve all the problems of the direct sunshine effect. If the temp sensor is really very close to the ambient air, in a more direct relationship, so to speak, than with the casing, then it should be bloodily accurate.
So just a faulty factory calibration can 'steal' its accuracy, which can be easily solved with adding a temp calibration / setting menu.
Please take my congratulations for this clever design.
DennyS
Post by DennyS »
Is there a difference in temperature readings (and its effects on other measurements) between black and white Newton models?
We are seeing excellent temperature immunity in the Newton.
The white case absorbs less heat than the black case, so temperature should be a bit closer to "actual" with the white model. Other than that, there are no meaningful performance differences.
