I've mounted the iBike Dash on my Specialized SL2. I took off the stem cap (which is eccentrically shaped) and simply attached the iBike stem mount. There is a small gap around the mount, not sure if there is any chance of debris getting in there.
How are other folks (if any) using the stem mount with recent specialized stems? I could just put in over top of the Specialized cap...
iBike stem mount on Specialized Pro-Set Stem
- lorduintah
Re: iBike stem mount on Specialized Pro-Set Stem
I put a 5mm space ring in underneath the ring.
