This morning I plugged in my iPhone and was asked to update the firmware, which I did successfully.
However, it now doesn't display or record any readings. All sensors are present and correct.
Screenshots below:
What do I need to check?
I'm running the latest version of the app.
Not recording ride!
Re: Not recording ride!
If your screen is blank try swiping to a different screen and swipe back and you should be able to see your readings.
If that doesn't work then remove your iPhone, reinsert it and relaunch the app.
