I am new to the concept of training with power, as I recently got myself an iBike Pro Gen III with wired cadence and speed after my el-cheapo computer died (2 years of hard abuse was a bit much for the poor thing).
Anyway, the iPro has been a lot of fun to use. The additional information has been invaluable, and in the short time that I have had the unit (couple of months), it has already made a serious difference to the way I ride, my abilities as a rider, and the value of the training that I do. So I am a happy iBike customer, and a strong advocate of the value of the unit whenever I am asked about the gadget.
Never having used an SRM or PT .. I am probably not qualified to make any comments about the accuracy of the power figures ... but ... I will say that the numbers I am getting are consistent with the effort that I put in, and thanks to adding Golden Cheetah to the mix, I can genuinely see consistency and improvements in my output over time. I am not training for the Olympics or anything .. so I am happy to say that whatever this gadget is measuring, it is perfect for riders in my position. Like the millions of other semi serious enthusiasts out there riding bikes, the iBike is a perfect companion on the ride.
Im OK with the battery life issue as well - that is not really a problem, once you plan around it and pay attention to the voltage figures of the battery. No complaints there. In fact, its an awesome design, since you can do a long distance multi-day trip and carry enough CR2032 batteries with you. You cant do that with a recharger unit.
The one remaining issue that I have with the iBike is this waterproofing thing. It has been a source of some frustration. I have other electronic devices on my bike - such as a watch that I use for an interval timer with audible alarm, and my cheap mobile phone that occasionally gets a bit wet on the road. All of these devices cop some water and handle it without complaint. Also my previous el-cheapo computer which never had a single issue with heavy rain, severe storms, hurricanes, tornadoes, or falling meteor showers
My iBike on the other hand, water is a huge problem. I am not talking about riding underwater at depths of 100m or anything - I am talking about any short duration of the lightest rain. 9 times out of 10, a little wisp of rain will manifest itself with a complete loss of speed reading. The head unit continues to work for a while, and the cadence never has a problem .... its just the speed sensor on the front fork seems anything but waterproof. This of course leads to a power reading of 0 .. and any prolonged period of zero reading after that leads to a power shutdown as the unit believes it is idle.
This has been frustrating .. but Im not complaining at all. I see the iBike as a magnificent idea, and something that I personally want to make perfect. I believe that maybe 5-10 years down the track, a completely bomb proof, low cost data acquisition device like this will be a regular part of cycling for the masses. I hope so.
Anyway ......
I have a 160km ride coming up this weekend, and the weather looks like bouts of serious rain for the day, in between sections of sunshine. I am praying to the Gods of cycling that I can get a full data reading for the event, but at this stage that is probably unlikey
So here is the plan for this weekend :
Speed Sensor:
I believe the speed sensor is the main cause of the problems so far. I can say this because the cadence reading is consistently fine in all weather conditions, so that has to point the finger of blame at the speed sensor. Im going to try a ghetto engineering solution here by :
- Coating the speed sensor unit with a thin layer of vaseline (hydrophobic, non conductive petroleum jelly), paying particular attention to the joint where the wires enter the unit.
- Wrapping a layer of strong flexible plastic around the fork leg, covering up the speed sensor .. with electrical tape tightly securing each edge of the plastic cover (a sandwich bag cut to size should do the trick I reckon.) I will have to give the plastic cover a decent set of drainage holes at the bottom .. just in case it actually collects water and just makes the problem worse !!
That should cure waterproofing the speed sensor .. I hope. I am also trusting that the thin plastic + a bit of vaseline will not interfere with the magnetic pickup. It should be fine for that.
The only other concern with this approach is the long term effect of vaseline on the plastic coating of the wires, and the plastic used to make the speed sensor. Worst case is that it melts the plastic over time ... at which point I upgrade to a wireless unit anyway and try again.
Head Unit:
Ill smear a little vaseline around the point where the wires go into the head unit, as per the speed sensor.
With my head unit mounting, I use a little carbon fibre extender bar to mount the iBike just forward of the handbars in a nice clean airstream. This places it centrally over the wheel, and forward enough to provide easy vision without having to look down too far.
Photos:
As you can see from the second photo, this does expose the underside of the unit to a potential bit of spray from the front wheel. The front brake does catch most of it, and after a ride, it is pretty dry under there, but it is one area of risk.
So what I am going to try and do under here is build some sort of aero looking splash shield to cover up the underside of the unit, and hopefully avoid any possible splash that is coming up from the wheel.
See the photo here for an artists impression concept of the splash shield :
This should be easy enough to make a solid prototype :
1 - Take some measurements.
2 - Create a mould in plasticene or some sort of putty that matches the shape.
3 - Place plastic sheet in the oven for a few minutes to soften it .. take it out, and then press the plastic sheet into the mould.
4 - After cooling, give the sheild of quick spray of matt black paint, let it dry, and then figure out a way to attach it under the unit.
For the plastic sheet - Ill see if I can get some 1-2mm styrene stock sheet (available from all good modelling shops). If I cant get these parts by Saturday, Ill try making a splash shield from a plastic bottle. The top section of most large plastic bottles is a perfect shape to cut a splash shield out of. Quick spray of black paint, and it will look the part too.
Anyway, Im determined to make this device work in the worst possible weather conditions, so any feedback or suggestions on the above would be most appreciated.
