Bottom display shows CAL & HR - no cadence!
aytchkay
Post by aytchkay »
I woke up to 31 deg F! By the time I started my ride it was around 40 deg F. - Chicago skipped summer and Fall this year!
When starting out my iPro Gen 3, wireless, paired with HR-Cad-Spd. As I started riding, the bottom readout showed "CALories" , and nothing else!
When I got home, I went to setup and saw that there was only one item paired - it must have been Spd because I did get speed readouts.
I re-scanned and all 3 were paired. Started riding again, but only CAL and HR were indicated - NOT CADence.
How do I get CAD back?
Re: Bottom display shows CAL & HR - no cadence!
Please confirm that your cadence magnet is passing very close to the notch in the cadence sensor--there should only be about a 1/8 inch gap.
Then, try your experiment again and see if you get cadence.
If not, remove the battery from your cadence sensor, put it in backward to hard-reset the sensor, then reinsert normally. Wave the magnet past the cadence sensor. WAIT ONE MINUTE, then try the Scan process again.
Let us know what you find.
aytchkay
Post by aytchkay »
It worked!!
thanks so much.....especially for your rapid response. Velocomp support is tops.
howard
