How to compare positions using ibike wth Power Meter
dmc
Post by dmc »
How does anyone else use the ibike to compare different positions for Cda?
Do you do a new cal ride for each position set up?
Or do you just keep the profile set and look for changes within a file?
I tried the latter method, but I am finding it difficult to extract a Cda for the different runs, set as laps within a file.
I can use powermeter comparison to see a graphical representation of the change in Cda, so the data is "in there".
Just tryin to figure out how to extract a Cda for a given lap split from the info.
I can read both average SRM power and average Ibike power for a given lap split and so see a watt saving - but how to turn that into CDA?
The ideal would be for the Cda graph on powermeter comparison screen to
1 -have the option to view lap splits
2- Display averages of the cda's being graphed.
In general I am liking the new firmware and software. But there seems to be a lot of ability to look at graphical representations of info but an inability to read this same info as numbers/data. Eyeballing a graph seems an imprecise way to try to quantify drag changes!!!
DMC?
rruff
Re: How to compare positions using ibike wth Power Meter
Post by rruff »
If you are ok with a bit of fiddling, you can always model the course to pull out CdA... you don't even need the iBike for that. The Aero version is specially designed to do what you are describing... but if you don't want to upgrade to that, you'll have to do a little work. Or... just be happy with the delta avg watts you are seeing now.
