AeroPod CdA Connect IQ app for Garmin
agud
Re: AeroPod CdA Connect IQ app for Garmin
Post by agud »
Hello I had install AeroPod connect IQ on my garmin 520 , i can see it on the folder apps on my iMac , but not when i start my 520 i can not see it
can you help me??
thanks
mir
Post by mir »
It is only available as a data field which can be added to an activity screen.
agud wrote: Tue Aug 20, 2019 8:15 am Hello I had install AeroPod connect IQ on my garmin 520 , i can see it on the folder apps on my iMac , but not when i start my 520 i can not see it
can you help me??
thanks
Please refer to pages 8-11 of the instructions, which tell you how to set up a CdA screen in your Garmin.
AeroPod_ConnectIQ_073119.pdf
(2.45 MiB) Downloaded 646 times
DaveQB
Post by DaveQB »
Hi Velocomp,
How do we ensure we have the current Connect IQ App? Is the first post in this thread regularly updated with a link to the current version? It looks like it's currently a year old.
Thank you.
DaveQB wrote: Thu Sep 05, 2019 12:31 am Hi Velocomp,
Thank you.
It is the most current version. If there is an update we will update the link.
DaveQB
Post by DaveQB »
Velocomp wrote: Thu Sep 05, 2019 1:01 am It is the most current version. If there is an update we will update the link.
Great. Thank you.
syll1914
Post by syll1914 »
garmin made a update and now I can t see slope/wind...what can I do?
syll1914 wrote: Tue Sep 17, 2019 9:30 pm garmin made a update and now I can t see slope/wind...what can I do?
Please be more specific about what Garmin did...
syll1914
Post by syll1914 »
Velocomp wrote: Tue Sep 17, 2019 11:52 pm
after last update 8.0 which I made it yesterday ( for garmin edge 1030) i could see just power...in rest, just lines , like the aeropod was off...tried to reconnect, make a new screen..but nothing
syll1914 wrote: Wed Sep 18, 2019 1:44 pm
I have ordered a 1030 and will provide an update soon.
Problem solved: see here:
https://velocompforum.com/viewtopic.php?f=98&t=5274
xophe
Post by xophe »
Hello,
Is the Connect IQ app compatible with the Garmin 935 watch? If yes, can someone share a screen picture?
Christophe
Garmin lists the 935 on their website as a ConnectIQ compatible device, so you should be OK.
https://developer.garmin.com/connect-iq ... e-devices/
xophe
Post by xophe »
How it is possible to display the same fields on a watch than on a bike device?
The Garmin 935 can only display 4 data.
AeroPod CdA data is only one field.
reiskayser
Post by reiskayser »
Hi John, back to the 1030, I have carefully made 3 attempts to solve the v.8 update problem to get the CdA screen to go live (no dashes) including resets on both devices and still only get power. Have other been successful with your fix? Do you have any other suggestions? Thanks, Reis
Did you do this?
Are you sure your AP is "on" (shows solid green when button is clicked)?
reiskayser
Yes
reiskayser
I get a power reading
reiskayser
Also, the power reading seems to work fine.
Sorry, I have nothing to add. This is a Garmin problem.
EHB
Post by EHB »
Do you happen to know if it requires a USB connection to the device? My forerunner 735XT is very temperamental about connecting over USB, but connects to the Garmin phone app over Bluetooth fine. My Garmin account has the watch registered, it just doesn’t appear in the ‘Garmin Express’ app much.
What does connect well is an Edge 530, but that isn’t in the list of devices it works on, even though it has connect IQ and the model earlier (520) is listed. Don’t know what is going on there. Thought it would be added by now.
Installing the ConnectIQ app requires that your Garmin device appears as a USB drive.
I know this works for traditional Garmin bike computers but I don't know about the watch, and how it connects to the computer.
EHB
Post by EHB »
Sod. The watch is flakey over USB. Do you think it can be installed on an Edge 530? It’s very similar to a 520 and always appears via USB.
EHB wrote: Thu Jan 09, 2020 7:14 pm Sod. The watch is flakey over USB. Do you think it can be installed on an Edge 530? It’s very similar to a 520 and always appears via USB.
I'm guessing that it will work on the 530.
EHB
Post by EHB »
I did an experiment last night before your reply & I think you guess right. I created a new profile called TT on it and followed your instructions. It seems to have worked, but unfortunately I can’t test it as my one bike with a DFPM has no brakes currently. I removed them to hide them from the sweat I generate indoors. If I cycle indoors and put it in front of a fan will it show numbers?
EHB wrote: Fri Jan 10, 2020 11:43 am I did an experiment last night before your reply & I think you guess right. I created a new profile called TT on it and followed your instructions. It seems to have worked, but unfortunately I can’t test it as my one bike with a DFPM has no brakes currently. I removed them to hide them from the sweat I generate indoors. If I cycle indoors and put it in front of a fan will it show numbers?
It worked on the watch, or the 530?
You will see small variations of slope and wind speed on your indoor trainer.
EHB
Post by EHB »
On the 530. Given up on connecting the watch via usb with this firmware.
I thought of a problem with my plan of testing it by putting in front of a fan though: the cal ride.
EHB wrote: Sun Jan 12, 2020 11:36 am On the 530. Given up on connecting the watch via usb with this firmware.
I'm not sure what you are trying to accomplish. If it is simply seeing if your ConnectIQ app is working, then leave AP set to an existing, calibrated outdoor profile, and ride on your trainer. The power numbers will be garbage but you should see changing slope and wind.
syll1914
Post by syll1914 »
nothing new here?..about a new graph..I m using AeroPod just like a only powermeter..will be nice to be able to choose what I want to see on my garmin
