PowerPod pairing with Mio 505HC
Hanniolo
Post by Hanniolo »
Hi there
Last week I received my Power Pod.
I'm having trouble pairing with the Mio 505. The speed sensor pairing is not a problem but the Mio does not see the PowerPod.
The light on the PowerPod to flash for 25 seconds green.
I hope you can help me.
Thanks in the future
Regards Han
Re: PowerPod pairing with Mio 505HC
If the PowerPod light is flashing green then it has not "found" the ANT+ speed sensor to which it was paired previously.
Wake up your ANT+ sensor, then click the button to wake up PowerPod. When the speed sensor is found the light will turn solid green.
AFTER the light is solid green, ONLY THEN will PowerPod start broadcasting its power signal. When the light is solid green you may pair PowerPod to your Mio 505
Hanniolo
Re: PowerPod pairing with Mio 505HC (problem solved)
Post by Hanniolo »
Thanks for the quickly answer..
The problem solved!
I have just do it and the PowerPod paired with the Mio 505 :D :D
Many thanks!
