Hi:
Is there already a software function or is one planned that will allow smoothing of the cadence for times when you are coasting? It is not essential but would make the graph easier to read. I would still rather that the calculations continue as they are with respect to average, max cadence etc. It's just a visual thing. Thanks!
Cadence smoothing?
- lorduintah
Re: Cadence smoothing?
If it is the zero cadence values and range of the plot that are at issue, you can click on the min value or max value on the graph's y-axis scale and type in a different value. This will allow you to, for example, raise the min from 30 to 50. Then lower cadence rates will just fall off the bottom of the plot.
