iSport & Coast Downs
gayeskin
Post by gayeskin »
Did a couple of searches but couldn't find a direct answer.
I am still a little confused about coast downs. How many coast downs are recommended to get accurate information? Does the software average it out if you do 10 coast downs? Also, I am not sure if the iSport would be able to store those coast downs since i believe it does not have the memory like that of the iPro or iAero.
Thanks in advance
Nathan
Re: iSport & Coast Downs
With the iSport, only the most recent coast down is used. So, if you do 10 coast downs, 9 of them will be for exercise only... :D
Don't forget too that you can use the Est CdA function to eliminate coast downs altogether!
gayeskin
Post by gayeskin »
Thanks John!
