How to turn off the iAero
oldfartrunner
Post by oldfartrunner »
Searching for 45 minuites throught the manuals and there is no mention of how to turn off the iBike (iAero).
John Evans
Re: How to turn off the iAero
It should turn itself off after 20 minutes or so.
If that doesn't happen the remove your battery, insert it backwards for a few seconds to hard-reset your iBike, then reinsert the battery normally.
R Mc
Post by R Mc »
or. . . go to set up, scroll through til you get to the battery screen (it will show voltage), then press the center button. The unit will turn off.
oldfartrunner
R Mc wrote:or. . . go to set up, scroll through til you get to the battery screen (it will show voltage), then press the center button. The unit will turn off.
Thanx ... this technique works great!
John Evans
