editing ride data within iBike2 software
jasonod
Post by jasonod »
Richard et al,
Is there a way to edit out power spikes after or before analyzing ride data? Even after analysis, I still had a power spike to 800 watts.
Jason
markmergler
Re: editing ride data within iBike2 software
Post by markmergler »
You can open up the file in Excel and edit the raw data - not sure if this is advisable though.
jslopez93
Post by jslopez93 »
Would be really cool if you could (via bike software) just pick several points that you can drag up or down.
markmergler
..or how about being able to enter a personal 'max power threshold' in the user settings so that when the ride is analysed the software can use this to look for any spikes and then give you the option to have them replaced - the trick is what to replace them with - I'll leave that to the guys with bigger brains than me ;)
Site_Admin
Site Admin
Post by Site_Admin »
We don't want to compete with CPS/TPS, which can do that. However, I'll help anyone set up their CPS over the phone if they want it.
travispape
Site Admin
Post by travispape »
markmergler wrote:..or how about being able to enter a personal 'max power threshold' in the user settings so that when the ride is analysed the software can use this to look for any spikes and then give you the option to have them replaced - the trick is what to replace them with - I'll leave that to the guys with bigger brains than me ;)
Good idea!
When when I say "good idea", what I mean is that I've had an idea just like this in my todo list for months now. Unfortunately it won't be bubbling up to the top soon.
Travis
jslopez93
Post by jslopez93 »
Whareagle wrote:We don't want to compete with CPS/TPS, which can do that. However, I'll help anyone set up their CPS over the phone if they want it.
I know you can (similar to opening an excelt file) display the CP data in numbers instead of graphs and then changing individual entries.
A bit to tedious for me so I was hoping I could select a bunch of data points and then scale them down as a group. Is this possible?
travispape
Site Admin
As simple as what you are asking for sounds, it's not that straightforward. If you drag your power to where you think it should be, in most cases iBike 2 would undo your work and put the power back to where it was if you do another auto-analyze (or analyze tilt & power).
If you could, send me your ride file so I can look at the blemish you want to edit. I want to see what is going on to cause the problem--maybe I can get the analysis to find and correct it automatically.
Travis
jslopez93
Post by jslopez93 »
Travis
Ride files are usually spot on but I am wary about the trainer watts which in my case seem to track a bit high. I'm not too concerned about being extremely accurate on the trainer but I'd rather err on the low side there.
Anyway to set up the ibike on the trainer so we can "adjust" the results. I'm thinking just tightening the resistance to the wheel may do it but no idea on what else to do.
travispape
Site Admin
[quote="jslopez93"]Ride files are usually spot on but I am wary about the trainer watts which in my case seem to track a bit high. I'm not too concerned about being extremely accurate on the trainer but I'd rather err on the low side there.quote]
Ah, that's different. My todo list has the fix you need for trainer mode. Of course it doesn't do you any good until I have time to implement it. I'm simply swamped.
In the mean time, you can add to your resistance by lowering your tire pressure.
ldmitruk
Post by ldmitruk »
I know this is an old thread but it addresses a question I have.
I got a some ride files that have spikes in the power I'd like to correct, often just a few values. What's best way to determine a value you should use to replace the incorrect data? In the attached file starting at km 13 I get some really over the top values for power. Any suggestions would be much appriciated.
Cheers!
iBike_08_30_2008_1053_56_km.csv
(795.84 KiB) Downloaded 373 times
I think the problem is the spike in speed. If you open the file in Excel you can see the speed become erratic at 13.3327km. If you correct those speed numbers to about what they were, then save and open the file in iB2. Click Auto Analyze and the correction should be made. Experiment on a copy of the file for sure.
22.531 15.744 381.421 13.301
39.429 17.251 574.702 13.306
81.111 17.342 0.000 13.333
22.370 16.484 0.000 13.345
21.082 16.484 769.971 13.352
22.531 16.986 701.029 13.356
56.327 17.162 875.536 13.366
22.048 17.074 0.000 13.373
21.565 16.815 652.871 13.379
21.565 17.344 607.795 13.385
61.477 18.404 912.774 13.389
264.093 20.239 0.000 13.400
30.739 18.921 0.000 13.410
38.463 18.405 1278.742 13.419
20.761 18.405 991.376 13.425
20.922 18.007 855.844 13.431
21.726 18.609 724.848 13.435
21.565 18.305 618.234 13.442
21.726 18.305 541.718 13.448
121.023 20.126 1415.258 13.465
35.084 18.507 0.000 13.471
25.106 18.611 0.000 13.482
ldmitruk
Post by ldmitruk »
That did the trick. I'll have to remember to check the speed values when downloading from my iBike.
Cheers!
racerfern wrote:I think the problem is the spike in speed. If you open the file in Excel you can see the speed become erratic at 13.3327km. If you correct those speed numbers to about what they were, then save and open the file in iB2. Click Auto Analyze and the correction should be made. Experiment on a copy of the file for sure.
You should try and figure out why the speed spikes. The most common reason is that the magnet is in a unique position that makes it register twice. You might want to move it slightly. There is also the possibility that another magnet or sensor is too close to the speed magnet and you are getting a double hit although very sporadically.
