power disappears
namblor
power disappears
Post by namblor »
I love my new iAero, it is way more than I expected it to be, and fun to use.
I have experienced a problem on my last two rides. Everything records find, and appears on the screen in an orderly fashion, but when I download to my computer the power disappears (after showing up for one second)! I can uncheck the box "auto fine tune ride data" and it does not disappear, but the same vanishing act happens when I use the "analyze power" option.
I have uploaded the second of the two rides.
Sorry if this topic has been covered before!
TC
iBike_01_04_2009_1352_22_Miles.csv
(971.6 KiB) Downloaded 278 times
Re: power disappears
The reason for your problem is that there is an error in your profile. Specifically, in the "advanced" tab in the edit profiles function, you'll see your bike + rider weight listed as zero. This causes an infinite Crr.
I don't know why this problem happens in iBike 3 but I will try to find out.
The easy way to fix this problem is to use the Edit/Profiles command, then enter in your weight in the advanced tab, then save the profile. This will fix everything.
I will send you by private email your corrected profile.
namblor
Post by namblor »
That seems to have fixed it, thanks!
TC
