New Heart Rate monitor sensor.
Kcblair
Post by Kcblair »
Hello Guys, Had to replace my Heart Rate monitor sensor/strap . Will I need to do a re-calibration to add or just live without that data ? Data is also collected in my Garmin software .
Thanks. KB
Re: New Heart Rate monitor sensor.
Whenever you do a new sensor pairing then yes, that will force a new calibration ride.
There is a way to get around the forced new calibration ride in Velocomp Aero:
1) Do a new sensor pairing of all sensors
2) Connect your unit to VA
3) Select "Device/Configure Device..."
4) From the dropdown menu select "Config/Setup Calibration"
5) Select the Target Profile you are currently using, then select "Configure Manually"
You should be able to ride with your existing profile, but with your HR data added to your ride file.
