Speed Field appears blank
Speedyg
Post by Speedyg »
In the regular stats mode I cannot see the speed. That area is just black. Any way to change the font or the background? I assume what is happening is that the background and the font are both black.
Re: Speed Field appears blank
Place the cursor in the stats field, then right click. You will be able to select "Advanced Stats". This should fix the problem.
Return to “Velocomp Aero Software for Mac/PC”
