In Isaac if 2 ride files were generated because of a coffee stop part way through the ride, when I append the second file to the first Isaac creates a third file which combines the 2 rides and gives it a name incorporating the total ride. An analysis of the whole ride.
With Velocomp Aero I find that when appending the second part to the first a new file isn't created but the whole ride is incorporated into the first part and the ride name remains the same as the first part of the ride ie it retains the ride distance of the first part rather than the total ride.
Is there a way to append rides and create a new ride for the total in Velocomp Aero?
Velocomp Aero v1.0.22 - Appending ride files.
Re: Velocomp Aero v1.0.22 - Appending ride files.
After appending the file, rename it with the total file length, then use the "Save As" command to save the renamed file.
