In Isaac both Drafting (on Cadence) and Out of Saddle (on Elevation) were charted.
These two metrics are not in Aero. Are these metrics no longer available in the latest devices?
If the information is available, could Aero be updated to show these?
Drafting & Out-of-Saddle
Re: Drafting & Out-of-Saddle
I'll try to add it in the next release
- lorduintah
Once again John and his crew meet the calls from the fans!!
I also like the new scaling on the PowerStroke graph. Wondering on the time advantage - looking at the ride file in Garmin Connect it does not make a whole lot of sense.
I'd upload an example of each, but I forgot while image format the BB will accept - tried PDF, JPEG and PNG.
I have great difficulty uploading images. What I've found is that I need to change the name of the screenshot image, getting rid of the assigned name. I rename them simply to "1" or "2", etc, and then they upload without problems.lorduintah wrote: ↑Mon Aug 25, 2025 5:21 pm Once again John and his crew meet the calls from the fans!!
