Calibration support against DFPM
albafar
Post by albafar »
Today I thought I would try and see how close the PP was to my Powertap G3 Ant+. Turns out it is pretty close. But I can't seem to dial it in more precisely. If I focus on a flat section and reduce my CDA in Edit Profile it messes things up in other parts of the cal ride. I am confident John will be able to do some wizardry - please also explain how you go about it.
TWH_30_09_2024_cal_HiDef2.ibr
(316.53 KiB) Downloaded 1029 times
activity_17168111516.tcx
(358.6 KiB) Downloaded 1015 times
Re: Calibration support against DFPM
Your ride file shows that your average wind speed is a bit higher than your average bike speed.
Screenshot 2024-10-02.png (9.22 KiB) Viewed 37979 times
This would cause PP watts to be slightly higher
The way to fix this is to manually adjust the wind scaling factor in VA, such that wind speed equals bike speed. A wind scaling factor of 1.0 (determined by experiment) does the trick. DFPM and PP are within 1 w of each other:
Corrected ride file an profile attached.
TWHcombined_corr_30_09_2024_cal_HiDef2.ibr
(315.37 KiB) Downloaded 1059 times
corr.ibr
(315.38 KiB) Downloaded 1055 times
albafar
Post by albafar »
Thanks a lot John. That makes a lot of sense. The average power gets dialed in. But how about the Max numbers - how come they are still so much apart?
In looking at your ride file I see that you had, one time only, a 4 second interval where your DFPM power was a bit higher than your PP power. Two points:
1) Assessing cycling performance (or power meter performance) on the basis of a single 4-second burst of power is not terribly meaningful
2) At extremely short intervals, HOW the power measurement device measures stress becomes important. It's possible your DFPM over reported the maximum stress it experienced; it's possible your frame flexed a little bit, causing PP to underreport watts. It's possible, even likely, that there was a combination of these factors, and perhaps others.
Who knows?
After looking at ride files for 20 years, the only thing I know for sure is that no measurement device is perfect, and that the benefits of power measurement are most reasonably assessed over the course of an entire ride.
Screenshot .png (41.25 KiB) Viewed 37842 times
albafar
Post by albafar »
Thank you for elaborating on this John - highly appreciated.
As I thought it might have been a bit too windy on the test day, I went for another test ride yesterday where wind was a bit calmer. The O&B ride was slightly longer than the one earlier this week but with the input you had provided I've tried to tweak the profile as good as I could: Alligning Wind and Speed and reducing CDA a bit. If I had kept CDA I would have had to tweak crr, I assume. For the actual power numbers I guess it doesn't matter which variable I tweaked. But as I chose to ride with elbows semi-bent as I do most of the time I decided to tweak the CDA numbers. On the screen everything looks spot on to me - as good as it gets, I believe. Do you agree?
TWH_04_10_2024_cal_HiDef.ibr
(119.13 KiB) Downloaded 1027 times
Yes, this setup and calibration looks excellent!
albafar
Post by albafar »
Awesome - I guess I've got my head around things now. Thank you so much for your continous support to the community John :D
